No signal on display after building pc.
quicktype8
I have seemingly connected everything perfectly in my pc as fans turn on and lights turn on on the gpu and motherboard but theres no signal on my display.
Ryzen 1600
B350 f Asus strix mobo
2x8gb lpx vengeance 3000
Gtx 1070
Corsair 500w
Aoc G2460V
1) First off, there's no iGPU in Ryzen CPU's. They will only be in the APU's when they come out, not CPU's. So there's no point in connecting to the motherboard to test video.
2) Has your MONITOR been tested with anything else?
- if not, attach it to another PC, or
- use a different monitor or HDTV with the PC
- use a VIDEO CABLE that has been tested elsewhere (i.e. HDMI cable from BluRay player)
3) Do you have a spare GRAPHICS CARD you can swap with the GTX1070 to test?
4) Confirm that the power cables go to the video card, and the motherboard for the CPU?
5) Double check the DDR4 sticks are fully seated as per the motheboard manual recommendation (for position of sticks).
6) Is the CPU fan spinning?
See number 21 on the sticky:
'Have you tried resetting the CMOS? The motherboard manual will have instructions for your particular board.'
Go through every single part of the sticky i linked.
You've made a mistake.
The R5-1600 is supported as of BIOS 0401.
BIOS 0902 is simply the latest BIOS version, not the first one this CPU supports.
Just click the "CPU Support List" and it shows the first BIOS version for each CPU.
