Question no signal on monitor
coolguy93
7
hello my friend has a gtx 1080ti that has worked perfectly for some time now but today he got into bios and it got reset or something so from then he hasn't gotten any signal to his monitor when the displayport cable is plugged into the graphics card but it works perfectly when plugged into his cpu, the gpu is seen on bios but is NOT detected in windows. anyone who knows whats wrong?
The OP did that and that how it is getting display. just not with the 1080ti
coolguy93. check the modular psu cable on both end
That sounds like the graphics adapter is the problem. If you can't see it in Device manager, it's not going to work. Can you try another graphics adapter?
