Question No signal problem
ace1234567890-=
21
I was doing cable management inside my old pc that had a nvidia gt710 with core 2 quad and a 450 watt power supply,it was working fine until today after cleaning when turned it on there was no signal message on monitor so i removed the gpu and connected my vga cable to motherboard vga port then it perfectly booted is my gpu dead?
Could be, no telling until you check it somewhere else. Try next PCIe slot if there's one.
