Question No Signal to monitor after I boot up my PC
May 20, 2024
4
Monitor won’t post or get any signal after I reapplied new thermal paste to cpu and re-slotted my new ram. It’s showing DRAM/CPU lights atm (red led then quickly changes to yellow for longer)
…It was working just before I reapplied thermal paste.
Already tried clearing CMOS, checked for any loose cables, and removed/moved the ram sticks around. Still nothing. Anyone got any solutions, I need help
Here are my Specs:https://pcpartpicker.com/b/dM8J7P
You can try and relieve some stress on the mounting pressure for the AIO cooling block. See if that helps. As for your ram, are you working with the rams listed in your PCPP listing linked above? If you have an older kit of ram that's known to work, use them on slots A2 and B2, if you get POST, see if you can check what BIOS version you're on at this moment of time.
I did update my BIOS to the latest firmware for the 14900k a few weeks ago. As for the new ram sticks, I have them seated on slots A2 and B2 already, sadly I already sold my older kit a while ago.
Is there any way I can upload a clip on here? not seeing a media option
False alarm! It just was a bad connection on the ram part. I removed all rams again and slotted one on B2 and my monitor finally got a signal. Thanks for the help anyway
