Question No signal to monitor ?
Aug 12, 2023
7
So in my pc before there was a ryzen 3000 Vega and I wanted to upgrade to a ryzen 5600 but when doing so there was no display shown on my screen I’ve tried going back the the old one to update bios but even the old cpu is not working anymore. The pc boots up like normal but doesn’t show display I have a rx 6650 Xt and I’ve tried removing cmos and putting it back nothing happened and then even taking out the ram I don’t know what else to do
When posting a thread of troubleshooting nature, it's customary to include your full system's specs. Please list the specs to your build like so:
CPU:
CPU cooler:
Motherboard:
Ram:
SSD/HDD:
GPU:
PSU:
Chassis:
OS:
Monitor:
include the age of the PSU apart from it's make and model.
CPU:
CPU cooler:
Motherboard:
Ram:
SSD/HDD:
GPU:
PSU:
Chassis:
OS:
Monitor:
Cpu : ryzen 3
Mother board : A320M-DVS
RAM : 8GB TEAMGROUP
GPU :. Rx 6650 xt
Monitor : LG 75hz
I’m not sure about other specs
You probably already know your mistake, you should've upgraded the BIOS before putting the new CPU in.
Clearing the cmos and putting the old cpu back should've solved the issue. I assume you just pulled the battery out (I don't think your board has a clear cmos button/jumper), how long did you leave the battery out before putting it back in? If less than 10 minutes, try again and this time wait at least 10 minutes, or longer.
Last time I took the battery out for like 6min and put it back in so should I install the old one back in and pull the cmos out for 10min ?
