No signal to the monitor from the pc. Using a voltage converter.
Sweetiebelleswag
14
-Turned pc off last night normal and no issues
-come back from class today and turned it on
-pc turns on normally, fans and lights on the mobo are fine but no signal on the monitor
-tried different ports and different hdmi and restarting and still nothing
-monitor works fine with laptop
-mouse lights up but keyboard doesn't, tried multiple USB ports for KB still nothing but works fine with laptop also
-open pc take out ram gpu and power connectors and reconnect it all and still nothing
-try it without you and still nothing
-am using voltage converter explanation in context below
-tried resetting cmos and nothing
-tried booting it up without ram and nothing no beep and but not sure mobo would anyway
Context- moved to Japan 8 months ago and my psu is set to British voltage and doesn't support Japanese voltage. When I got here I found a Korean voltage converter so I ordered a plug adapter to connect my British plug from the British pay to the adapter and then to the Korean voltage converter. Sounds complicate but it worked and for the last 8 months everything has been fine. I have knocked the converter a few times but pc protected itself with surge protector.
Have I fried my Mobo or psu asked elsewhere they don't think so but I don't know. PC starts up like normal feels like there is an issue with psu or mobo but I just don't know.
Specs are an Asus h81m-plus
Corsair vs650
Amd 390
And I think a i5 4690
Monitor is AOC
