No Sound But Drivers Installed
G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.hardware (More info?)
i have no sound atall but they are detected in device
manager and i dont understand it wont play in media and
it say no sound installed im confussed can sum1 help me
Try reinstalling your sound card drivers. Use Everest Home from
www.lavalys.com to find out what sound card you have and it should
provide a link to the proper drivers for you 😉
Nathan McNulty
The solution is described at
http://www.annoyances.org/exec/forum/winxp/t1066427444 and I repeat the brief
version below (you need to reinstall the driver swenum.sys but first you must
create a .inf file for it):
"copy machine.inf from %windir%\inf to a temp dir
remove line 20: ExcludeFromSelect=*
add new hardware have disk (select the temp dir with the modified
machine.inf) and install the plug and play software enumerator"
> Nathan McNulty
