No sound with hdmi to tv
mastergamer2014
47
Hello,
I have windows 10 home 64 bit and my sound was working fine two days ago and now it will not come through my tv speakers. I updated my drivers, did a system restore, rolled back the realtek drivers and nothing is working. Also it comes up as high definition audio and it says it is unpugged.
thanks in advance. :)
Try a different cable?
If the High Definition option in Sounds is showing up as Unplugged, then either the cable is unplugged, the cable is faulty, or the HDMI port on the graphics card has failed.
-Wolf sends
Turn off the TV and shut down the computer.
Turn the TV on and then boot the computer.
If you still do not have audio through the TV speakers (and your audio output is set to HDMI), try a different HDMI input on the TV using the same procedure as above. Shut everything down, switch the TV input, turn on the TV, power up the computer.
-Wolf sends
sadly didn't work any other suggestions.
