Question No USB header for Bluetooth/Wifi Card - Help!
Jan 24, 2023
I have a precision 3650 dell computer at work that I would like to outfit with a wifi/bluetooth card to be able to work from home. The precision 3650 motherboard diagram is here: Motherboard Diagram
I would like to install this wifi/bluetooth card: Wifi/Bluetooth Card
This card (and all others similar) require an extra USB2.0 header on the motherboard to utilize the bluetooth functionality of the card. I know that I could use a jumper from external usb port to a header like this: USB2.0 to Dupont
But that just seems like a very janky and jerry-rigged set up to go from the exterior to the interior like that and was wondering if anyone could come up with a reasonable interior solution to this! I could also be totally missing something obvious so let me know. Any help is appreciated!
That "EDUP" Wifi adapter uses the internal USB header for Bluetooth... for some reason.
This seems unnecessarily complicated. Either a PCIE Wifi/Bluetooth adapter:
Example: https://a.co/d/4IWdfET
Or USB device(s) - typically it'll be cheaper to have one for Wifi, one for Bluetooth - example(s):
https://a.co/d/6F8KjiG
https://a.co/d/gg226q1
Not enough info to know your exact model for the motherboard, but there may well be an M.2 slot
https://www.dell.com/support/manual...b1eb84-0c9d-4d7a-a03d-963321ee94fa&lang=en-us
In which case, you could use that instead. Example:
https://a.co/d/0SDvUnF
Thanks for the reply! I probably will just end up using the pci-e slot card for the wifi, and then just getting a separate bluetooth dongle. I looked into the m.2 network cards that you mentioned, and this particular motherboard only has m.2 sockets keyed for M & B types instead of the A or E types needed for the network card. Bummer.
