I had a Ryzen 5 1600 build in an ITX form and everything ran smoothly. I recently purchased 16gb of DDR4 3000mhz RAM (originally had 8gb 2133mhz stick that worked fine too) which technically wasnt supported with my motherboard but overclocked perfectly fine to 2933 via bios. I also had it paired with a 1060 3gb and Corsair 550w psu. Everything ran smoothly. I purchased a mini gtx 1070 from ebay which had been repaired by the manufacturer due to some power issue according to the seller. He assured me the card was fixed and functional.
When I put the new card into my pc, I no longer received an image on my monitor, and no power to my USB devices (keyboard, mouse, ext. hdd, etc). I had assumed maybe my psu blew or my motherboard went out. I proceeded to replace both (upgraded to 650w Corsair PSU) and am still having the same exact issue. Even with the GPU unplugged from the motherboard, im getting no power to any of my usb devices. Could this potentially be due to my RAM dying out (I decided to ditch the ITX build and go full due to pricing issues) and my new case has not come in yet though I did try an out of case test build to see if everything would boot up. I havent tried switching to 1 stick of RAM at a time or even put in the old 2133mhz stick.
Or could the issue be due to the gpu itself? I couldnt imagine a GPU could cause a computer to essentially not boot and no power to USB, but im honestly not sure. Im praying its just faulty RAM (will test tomorrow when my case comes in and I can build).
Side note: when I power the computer on, all motherboard lights turn on, the cpu cooler fan spins, and the gpu fan spins and then stops (im sure it does this normally as its not under load). So it seems like im getting some power and functionality. But no video or power to any of my usb devices. Also no sounds, like no beeps or anything. Tried searching around for answers to this and havent been able to find much help
