Question No wifi connection but ethernet connection for my ASUS RT-AC68U router
michaelyum
30
My RT-AC68U router can't connect with any wireless devices at my home. The two 2.4GHz and 5GHz indicators are on.
However, the ethernet connections are fine. I have updated the firmware to the latest yesterday. I restarted the router a few times and at times, the wifi connection worked for a while and then died. Any insight or suggestions?
I just reset the router and have had a solid connection for about 3 hours.
I am not from the US, just asking here because this site is great. Thanks
k man the reason i might have been able to tell you is iv had almost every isp in the usa and cannada and i keep almost all the setup manuls and most of the time you have to go to the website on self setups to get your wifi ready but the earthernet works
