Question Noctua CPU Cooler
muratt1989_
48
Hey guys.
I am building a new pc and got myself a Noctua Cpu Cooler. The mobo is MSI X670E Socket Am5 and my cpu is AMD Ryzen 7950X3D.
The cpu cooler has both am4 and am5 base for different type of motherboards. However, when I use the AM5 chasis, the cpu cooler looks upwards hence the fans facing upwards. Ive had exactly the same pc but with a different CPU cooler. (Im building this for my sister).
What am I doing wrong here? Should I mount the AM4 chasis on top of the AM5 chasis as well? Ive found this quite bizarre.
Thank you
EDIT: There are the images:
images
It doesnt work with AM4 and it looks upwards when I use the AM5.
Noctua have a number of CPU coolers in their portfolio, both in stock and EoL, which one do you have?
When posting a thread of troubleshooting nature, it's customary to include your full system's specs. Please list the specs to your build like so:
CPU:
CPU cooler:
Motherboard:
Ram:
SSD/HDD:
GPU:
PSU:
Chassis:
CPU: AMD Ryzen 9 7950X3D 4.2 GHz 16-Core Processor
CPU cooler:Noctua NH-D15 SE-AM4, AMD AM4 Premium
Motherboard:
Ram: G.Skill Trident Z5 Neo RGB F5-6000J3636F16GX2-TZ5NR 32 GB 2 x 16 GB DDR5 6000 MHZ
SSD/HDD:Samsung 980 Pro 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive
GPU:MSI GAMING X TRIO GeForce RTX 4090 24 GB Video Card
PSU: MSI PSU MPG A1000G PCIE5 1000W 80+ GOLD POWER SUPPLY
Chassis
The cooler name and description says that its for AM4 for it has specifically AM5 metals and PC Builder didnt give any heads up for this.
