I bought a 120mm Noctua NF-P12 to replace my slow and weak Enermax enobal. Well, there is no difference in exhaust "power". What I mean is there is no more air coming out the fan as there was with the much lower CFM Enermax fan, its the same. The fan is facing the correct way its just not pulling out any air, what gives?
Just like the Enermax fan that was in there before this, the fan appears to be moving extremely, extremely slow, id say 400RPM. I can actually see the fan blades and make them out from the shadows, and if i cover the exhaust with my hand the fan obviously appears to struggle, changing speed. Would this be due to how I have it hooked up, a 3pin extention cable going to a 3pin to 4pin molex adapter which is pluged into a bunch of other crap. Should I try hooking it straight into the motherboard?
