Noctua NF-A14 PWM + Corsair H115i
Manny Calavera
19
Hi guys,
simple question, can I mount Noctua NF-A14 PWM fans on a new Corsair H115i AIO ?
Will it fit, how much of an improvement am I looking at regarding noise and performance?
Thanks for the info
yes its a 140mm fan and the H115i takes two 140mm fans. You can attach any 140mm fan, the mounting holes are universal.
Noctua are pretty much the best fans (hence why they don't care about their brown color) so they should run better/quieter than the fans you have now. Whether that means you can tell the difference between them though, I don't know.
