Noctua nh d14 or noctua nh d15 for silence
Alright, which is quieter of Noctua nh d15, nh d14, and BeQuiet! dark rock pro 3?
Case: Fractal design r5
Mobo: Asus z170-a
Corsair: rm850i
Samsung 850 evo 500gb
Ram: Hyperx savage 2666mhz ddr4
Gpu: Msi gtx 970 gaming 4gb
Cpu: i7 6700k
Cpu cooler: dont know yet, want the quietest one
Dvd writer: Asus DRW 24f1mt
Operating system: Windows 10
Here they say that the dark rock pro 3 is better and quieter though http://www.kitguru.net/components/cooling/luke-hill/be-quiet-dark-rock-pro-3-cpu-cooler-review/7/
Btw, Is the Nh d14 and the dark rock pro 3 enogh cooling for a i7 6700k? Would the coolers run slower on a i5 6600k that means more silence?
Ok, but can you answer my other quiestion too?:) Is the Nh d14 and the dark rock pro 3 enogh cooling for a i7 6700k? Would the coolers run slower on a i5 6600k that means more silence?
Btw dude! Thanks for helping me:) Seems like you are on 24/7 :))
Ok thanks, but in the review i linked to, they showed that the BeQuiet Dark Rock Pro 3 is a little , just a little bit quieter and is cooler than the Noctua nh d14.
Can these coolers run a i7 6700k? Do they need to run on high speeds with this beast of an i7? If i bought a i5 6600k instead, would the coolers run quieter and slower than if i used a i7 6700k?
