Noise from Hard Drive, but it passed bad sector test?
brenslick
41
I have a Western Digital Caviar SE16 640GB Hard Drive, and just today i heard a noise from it that gave me a mini heart attack. Its not a click, its not a screech, but its more of a rough noise that comes on for like 1 second and goes away, and comes back randomly. It seems to happen when its loading things like the OS, a big program, etc. Its not a horrible noise, but i worry more that i would usually because this is my first computer build, and ive had 2 power supplies die on me, and a video card died too. Its been about 4 months since i built it, and i thought i was past all of the problems. So, i downloaded Geeksnerds Drive check and did a bad sector scan, and after about 2 hours of scanning, it says my drive passed the test. So what do you think the noise means if the Hard Drive passed the test? Also, in the case of Virtual Memory, i have 2 GB of DDR2 running XP, so i wouldnt think virtual memory would make that much of a difference. Thanks in advance
First, do a r_manic says - start doing regular backups now! Then talk to Tech Support at WD. This does sound like a bearing about to fail, and they should advise you how to handle that. Hopefully they can do something more than wait for disaster before replacing it.
