Build Advice Not 5 but 9 years on... just a fan fix and new chip ?
ozaru
9
Back at https://forums.tomshardware.com/thr...for-business-not-gaming.2384578/post-15708736 you'll see that in August 2015 (!) I asked advice to build a PC "to last me 5 years". Incredibly enough, the spec shown there has lasted me 9 years with no changes, and still performs well.
However, now I need advice again on two aspects:
1) It can't be upgraded to Win11 (no TPM 2.0 on i7-5930k I think)
2) The fans are noisy... as in 'probably about to fail'. I think the problem is the CPU Fan (UEFI BIOS seems to show only CPU FAN @ 400rpm and CHA1 Fan @ 1300rpm)
Re 1), I'm hoping I might get away with just a new processor - but maybe I'll need a new Mboard too? If so, will that affect everything else?
Re 2) I guess it depends on 1).
Any comments welcome!
Thanks - but being devil's advocate to learn...
Could I not keep the 64GB of DDR4-2133 RAM - even if upgrading might increase speed?
Similarly, keeping the Samsung SM951 256GB M.2-2280 SSD would mean no need to re-buy Windows or reinstall anything.
Asus GeForce GTX 970 4GB could still be OK?
SeaSonic 660W 80+ Platinum PSU, Optical Drive, Fan Controller etc. could still be OK too?
In other words, I could get by just by swapping out the mobo & CPU for those shown below (selectly somewhat randomly from cheap options on UKPCPartPicker, but I'm guessing they're TPM-compatible)?
MSI X299 PRO ATX LGA2066 Motherboard
Intel Core i7-7820X 3.6 GHz 8-Core Processor
That i7-7820 CPU is not Win 11 compatible.
For the 850 pounds you're going to spend on those two parts you can build an up to date computer that would outperform the 7820x that is already 7 years old.
If that PSU is the original to the build it should be replaced.
PCPartPicker Part List
CPU: AMD Ryzen 5 7600X3D 4.1 GHz 6-Core Processor (£349.00 @ MoreCoCo)
CPU Cooler: Thermalright Peerless Assassin 120 SE 66.17 CFM CPU Cooler
Motherboard: Asus PRIME B650-PLUS ATX AM5 Motherboard (£149.99 @ Ebuyer)
Memory: G.Skill Flare X5 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory (£109.53 @ Amazon UK)
Storage: Crucial P3 Plus 1 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive (£62.99 @ Ebuyer)
Power Supply: Corsair RM850e (2023) 850 W 80+ Gold Certified Fully Modular ATX Power Supply (£94.95 @ AWD-IT)
Total: £766.46
Generated by PCPartPicker 2024-12-30 11:16 GMT+0000
CPU: AMD Ryzen 5 7600 3.8 GHz 6-Core Processor (£176.00 @ Amazon UK)
Memory: G.Skill Flare X5 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory (£104.05 @ Amazon UK)
Video Card: ASRock Challenger OC Arc B580 12 GB Video Card (£269.99 @ AWD-IT)
Power Supply: Corsair RM750e (2023) 750 W 80+ Gold Certified Fully Modular ATX Power Supply (£89.98 @ CCL Computers)
Total: £790.01
Generated by PCPartPicker 2024-12-30 16:36 GMT+0000
CPU: *Intel Core i5-12400F 2.5 GHz 6-Core Processor (£98.99 @ Amazon UK)
CPU Cooler: *Deepcool AG400 75.89 CFM CPU Cooler (£19.00 @ Computer Orbit)
Motherboard: *MSI PRO B760-P WIFI DDR4 ATX LGA1700 Motherboard (£119.99 @ Amazon UK)
Memory: *Corsair Vengeance LPX 64 GB (2 x 32 GB) DDR4-3200 CL16 Memory (£98.99 @ Amazon UK)
Video Card: *MSI GeForce RTX 3060 Ventus 2X 12G GeForce RTX 3060 12GB 12 GB Video Card (£249.99 @ Amazon UK)
Power Supply: *MSI MAG A750GL PCIE5 750 W 80+ Gold Certified Fully Modular ATX Power Supply (£79.00 @ Computer Orbit)
Total: £665.96
*Lowest price parts chosen from parametric criteria
Generated by PCPartPicker 2024-12-30 12:30 GMT+0000
Reactions: Flayed
Is there something about windows 11 that you need?
Other than fan noise, is there any performance problem or other issue that needs to be resolved?
The fan issue is resolved easily with a new fan for the existing cooler.
Since your windows license is oem. you will need a new license if you change motherboards.
Or, you can run using unactivated windows without any personalization capability.
If you might want better performance(who doesn't) look into a modern upgrade.
Your i7-5930 has a passmark rating of 10325 and a single thread rating of 2055:
https://www.cpubenchmark.net/cpu.php?cpu=Intel+Core+i7-5930K+@+3.50GHz&id=2336
By comparison a $320 Ultra 5 processor scores 43904 / 4660.
A 2 x 32gb ddr5 ram kit is about $200, and you can get 2 x 48gb for $300.
A new motherboard might be $200
A cooler might be $50
