not able to manually overclock
Owen_23
41
i have a gigabyte z270m-d3h motherboard and a i5 7600k but for some reason i'm not able to manually overclock i can use the preset to give myself a overclock to 4.6ghz but i know it will go higher if i could change the voltage and the frequency, i can't even change my ram settings and i know my ram will do 2400 mz
The i5 7600K must be cooled properly since it gets extremely hot above 4.0GHz.
Not all CPUs are the same, some i5 7600K won't go above their max turbo speed (4.20 GHz).
Can you explain the reason why you cannot change settings manually?
Are the settings not available?
Are the settings changes not saved?
Could you post all your system components.
MERGED QUESTION
Question from Owen_23 : "no voltage control"
The setting seem to not be able to be changed I have Adequate cooling and I am able to get to 4.6 ghz just by going to upgrade cpu and selecting i5 7600k @ 4.6 but I have no control other than that I am the admin of the system
Are you performing those changes in the BIOS?
Which BIOS version?
These are the damaged pins, I cannot tell you exactly which features are affected maybe someone else here might know.
If no one else respond, then you could open another post and copy that info.
PIN AW4: DDR0_DQ[45] / DDR1_DQ [13]
PIN C4: PEG_TXN[2]
PIN D16: BMP#[0]
PIN G36: VCCGT
hey so i think i might have found a work around for my overclocking problems i installed gigabyte easytune i'm still not able to overclock my cpu but now i can get my ram to 2700mhz, and i might be able to overclock my cpu if someone esle has a the software and a i5 7600k if they could send me 1 of their saved profiles i might be able to load it into the software, i am currenrtly at 4.6ghz @ 1.25v i would like to push it to 4.8 at 1.3v
