Recently built a PC but it doesn't boot up. LED light does flash for a few seconds once I turn on the power supply (RM 650W) but the fans do not work and it doesn't boot up at all. Could this be the fault of the power supply or the mobo?
Thanks, I will check with this tomorrow as it is getting very late here, hopefully this issue is resolved.What code is the LED signalling? Is there a Qcode display on this board?
What are the rest of your hardware specs including CPU and motherboard model as well as the model of your memory kit?
You should absolutely check everything HERE first:
**Click here for help troubleshooting hardware and No-POST issues
It was after I repasted it, I'm fairly new to building PC's and so I had not checked if the PSU worked prior to me reapplying paste. I shall check for any bent pins.You're right, it does not have a Qcode display, in fact I'm not even sure it has an LED code display either. I think you may need to have a system speaker like this in order to get boot codes from that board.
https://www.amazon.com/PC-Motherboa...board+speaker&qid=1553997926&s=gateway&sr=8-5
Did the problem start BEFORE or AFTER you removed the CPU and repasted it? Because it's definitely always a possibility of having a bent pin or pins on the CPU if the problem began after it was removed and reinstalled or if the problem has existed from day one.
Since you just built this, I'd say you definitely need to pull the CPU back out again and triple check that none of the CPU pins are bent, if you did not specifically check for that already.
I consulted the manual for the layout of the power pins, annoyingly they were all black wires but I believe I placed them in the right order. I shall check again. Connections to the PSU weren't too bad, the 24pin was difficult to place and might need checking. I haven't tried using only one dim of RAM, I will keep you updated on the results, thank you.Make sure the power pins are connected in the right order. They need to be a certain way. The manual will help. Also check all connections to PSU and components are in tight, no loose connections. Failing that make sure the fan on the PSU turns over. If it does and still nothing try boot into bios and restore defaults. Sometimes this sorts a wrongly/accidentally tweaked setting. And if you have a B bios (a second bios) try switching to that and booting. If it works it has a bios error of some kind and the other will need flashed.
If none of that works do a bare bones test. Take out all but one dim of RAM and boot it using only boot drive. If it works switch it out until you hit the problem and make sure the PSU is adequate for components. You can check out a PSU calculators online. It does look fine though based on parts listed.
Hope this helps in some way.
I have a friend who said that the thermal paste they put on the heatsink is not good so I used his thermal paste.I guess I don't understand WHY you removed and applied fresh paste, if the system had never even been able to power on and POST yet? Thermal paste isn't going to EVER cause a system to not turn on and POST. It can cause plenty of problems, but not that.
when the board boot first led is cpu then memory after gpu last one is complete boot proces check if any of those stay on and made sure all power ccable are fully in the board and ram is clip in same for gpu and the hdd .
Thanks, I will have a look today and check.I understand. Your friend is both wrong and right. Depending on what thermal paste he has, it may or may not be better than the thermal interface material (TIM) that comes pre-applied to most stock coolers including the AMD Wraith cooler, however, for a system that you won't be overclocking on the stock cooler does "ok", besides which, it's usually a good idea to make sure things are working properly BEFORE bothering to take more advanced measures like using aftermarket paste on a stock cooler.
I would just about guarantee based on this conversation we've had that you have a bent CPU pin but there are certainly other possibilities as well. I'd start there and look for ANY pin on the CPU that looks like it might be abnormal, obviously bent or discolored.
follow the order to see witch one it is you could see all in the board manual .
I have ordered it and it is coming tomorrow.Yeah, not really. The manual is just about useless in this regard. It says NOTHING about which LED color, or anything else, those LEDs are supposed to provide identification for the problem with. This is ALL the manual says, anywhere, about those LEDs.
It does however SPECIFICALLY mention troubleshooting with the system speaker beep codes, so unless you can find some board specific information regarding those LEDs elsewhere, I'd get as system speaker and attach it so at least you know which subsystem is causing the problem.
I have not yet tried checking the CPU but I did manage to use the internal speakers I bought. Unfortunately, there were no beeps at all. Does that indicate a mobo issue? (P.S. I am very anxious to take components out so I might get a friend or professional to do it for me if it needs complete disassembly, just curious as to what the problem may be).His manual doesn't describe anything about a sequence or stop codes. It ONLY shows what I posted above. I went through the whole manual. Nothing in there about any sequence under the board sections or troubleshooting section. Totally left out of the manual from what I could see. Not surprising since MSI often does things halfway.
