I was using an AC adapter that inputs 12v. The adapter that is for the monitor is 19v. The monitor is discolored and has lines running down it on one side. I was wondering if a lack of power could cause this issue. I have not used the monitor before so I don't know if it works properly. Trying to figure out if low voltage could be the cause before I bother buying the appropriate AC adapter.
