Not enough Sata power
Cyress
17
Hi, im making a custom build, but after installing new fan + fan hub + rgb dongle, usb hub and finally rgb led strip (corsair LL120 fan , silverstone fan hub , corsair rgb link , nzxt internal usb hub, corsair rgb led strip ) . Then i face an issue, they’re all powered by sata which i dont have enough on my psu to plug all those sata connector + 3ssd. Psu can drive enough power as its a 850wplatinum
So is there a dongle out there to split sata power in lets say 1in-5out or something else than y-splitter as im pretty sure those device dont use a lot of power
Thank you
I could not find a sort of Hub that provides many SATA power outputs on one box. Closest I could find was this concept. One is a Splitter that converts one 4-pin Molex female power output connector to four of the same
https://www.newegg.com/Product/Product.aspx?Item=9SIA9F95877121&cm_re=molex_splitter-_-9SIA9F95877121-_-Product
Then you could buy four of these items that each convert a female Molex to two SATA power outputs, and plug them into the four outputs of the first. The result would be eight SATA power output connectors drawing from one PSU Molex power output. It's not as neat as a single box, but is uses relatively few splitters and they're all black. I saw also a three-output version of that first item, in case you need only...
As i mentioned in the post. Looking for something else than y-splitter. Those splitter arent an option ( it will require to plug like 5-6 y-splitter on each other )
Any other idea ???
P.S. forgot to say that my build is purely esthetic ( custom sleeved psu and every single wire in the case
Then you could buy four of these items that each convert a female Molex to two SATA power outputs, and plug them into the four outputs of the first. The result would be eight SATA power output connectors drawing from one PSU Molex power output. It's not as neat as a single box, but is uses relatively few splitters and they're all black. I saw also a three-output version of that first item, in case you need only six SATA connectors for power.
