I have a 3.3 gHz 2500k cpu running at 4.5 gHz (on intel speed step so sometimes it spikes to 4.7 but usually stays below 2 gHz if it can get away with it).
It's loaded onto a z77 Maximus V Gene (mATX) board.
I just updated my 1600 12 gig mem kit (3x4) to a new 2400mHz 16 gig kit (2x8), but I haven't been able to get it past 1300 without encountering a constant black screen at startup.
I'm not sure if I'm doing something wrong, so I'll just put what I've done so far and hopefully someone can correct me if I've missed something.
After taking the old sticks out, replacing with the new ones (in the appropriate slots a2,a4), booting up, entering bios, switching from manual to X.M.P. - perpetual black screen. Went back in, switched back to manual, entered in the cas settings in the DRAM timing control, set the frequence at 1.65v beneath the 1.33v on the manual cpu frequency. Still, black. It's only when my computer "corrects" itself that the rig will boot up all the way. And it takes me settings way down - it took notches off my 46 enabled core values down to 44 and also downgraded my ram settings to 1.5v at 1900 (the only thing that didn't change was the timing, which is correct at 11, 13, 13, 31).
I'm wondering if it's worth trying to bump this to full 2400 or if it's a lost cause - so much as trying to OC my cpu past 4.5 gHz? In an ideal world, I would love to get my cpu up to 4.8 gHz and also have my new ram run at 2400 on its correct timings since I didn't purchase a 1900 mem kit!
Condensed:
ASUS Maximus V Gene z77
i5 2500K 3.30gHz @ 4.5gHz auto-clock (with Intel speed-step enabled)
Hyper 212 CPU fan
2x8GB DDR3 2400 mem kit
GTX 980 Ti (not oc'd)
Windows 10 Pro
Edit to add in PSU - 1000W ps2
Condensed:
Hyper 212 CPU fan
Windows 10 Pro
