Question Not posting , DRAM light on after doing cable management
frasbo
6
Was having problems with PC crashing (see my previous post) so decided to open it up, dedust, check connections etc. While I was at it I also decided to do a bit of cable management before plugging everything back in and booting up.
All of a sudden - not posting. Fans spin, RGB on but no signal to monitor. DRAM light turns on but reseating RAM/using a single stick has no effect. The pc was posting fine before so I struggle to see how it could be a hardware issue. Any suggestions??
specs:
5600x
RX5700 XT
corsair 650W PSU
MSI B550m mortar wifi
16gb corsair vengeance 3600 mhz
Lutfij
corsair 650W PSU
Corsair is the brand of the PSU while 650W is the advertised wattage of the unit. What is the model of the unit and it's age?
You'd be best served if you could pass on the link to your thread/post.
You might want to also pass on a picture of your PC's innards alongside the cablemanagement.
