Not running RAM at full speed, ASROCK Fatal1ty K4 ab350 motherboard
Aug 9, 2018
When I got this motherboard I knew that it wouldn't run at full RAM speeds, but I proceeded to get 3000 MHz RAM anyways because the bios was factory updated to support ryzen second gen, and it was, boy am I glad they were right about that, but my RAM is constantly running at 2400 MHz, I tried setting it to XMP 2.0 2933 MHz but it became unstable and game crashes happened frequently as well as one blue screen, but it boots into windows at least, which is good so for now I'm sadly running this at 2400 MHz until I can find a solution that will run it at at least 2933 MHz with it running very stable, unlike the frequent crashes I experienced when trying to do it myself, I tried XMP auto but since my RAM was not on the supported memory list it just ran it at the same speed, does anyone know a way around this, I've seen other articles like this but they're usually using first gen ryzen, I don't exactly know how well I should trust those because the first gen supported speeds are lower than the 2nd gen
