Not running with XMP, to get higher CPU overclock
Sunde-19
22
This may sound odd. But when i enable XMP, my CPU temp rises quite abit. This means that my I5-7600k will run quite hot, if i get it above 4.5ghz (with XMP)
If i disable XMP i can push it to 4.7ghz, before seeing similar temps. (around 75 degrees max on prime 95)
What will give me the best performance (i primarily use my PC to game)
Thank you for any insight.
