Not showing I updated to 12.4 Catalyst.
charon711
213
Hi, I just got the notification that Catalyst has updated to 12.4 . I downloaded the installer, uninstalled 12.1 , and installed 12.4 . But when ever Trixx loads or i bring up Catalyst Control Center it says i still have 12.1.
Is this a known issue with this version?
EDIT:
I have the Radeon HD 6850
fantastik250
Good at least it worked for you.
Yea, it's a bug currently with AMD, they know of the issue.
Flareside
124
Ok I am confused, I am lookting to try the 12.6beta drivers but the only ones I see are the CAP files on ait.amd.com. Could someone let me know where I am going wrong trying to find it?
Flare
danawesome89
106
Go here:
http://support.amd.com/us/kbarticles/Pages/AMDCatalyst126beta.aspx
Scroll down to where it says "instructions"
There should be links to download the appropriate driver for whichever OS you are running.
EDIT:
By the way, you need at least 5000 series or higher, I'm not sure what card you are running.
