Hello!
Basically my current network setup limits my speed at around 11 MB/s, due to my router being not all that good.
I'm not using the router all that often(though I want to keep it for guests and such), so I don't want to purchase a new and better one, so I was thinking of isolating the router so it only limits the speed of mobile connections.
Now, from what I have been reading there are 3 options that I have at the moment(a splitter, a switch or a hub). I see that these are quite different and I'm not sure which one might suit my needs better.
My ideal setup would split the connection from the modem separately to my 2 PCs and my router, so the speed available for the PCs is unhindered.
I would just connect my PCs to my modem, but it is not in my apartment, as far as I know(I rent the place so I haven't been here when it was installed).
Also, as a small mention, my speed(if it is unhindered) is quite high and I've read that it can be limited by some of these pieces of hardware(a splitter, a switch or a hub). I'd want to avoid that, if possible.
Thank you in advance!
