Not sure on temps 4790k
Daslicht
51
Not sure about these temps. I'm sitting at idle right about now. I have had temps running into 60's (63,65,65,58) at about 57% load. XMP is enabled for my ram but setting it back to default doesn't seem to change my temps. During games, ESO, Watchdogs, I have hit 50's for temps. Im not sure if I should update bios and reset my EVO 212. Please, any advice would be grateful. Okay, I am trying to get a screen shot of the hwmonitor and realtemp but cant get it to copy the image here.
Wait, is your VCore 1.7V ?
If yes, that`s WAY too much! The default I`m expecting to be something between 1.1 - 1.2 volts.
I`ve seen people OCing to 4.4Ghz using a VCore of 1.25V for 4790k.
If your VCore is actually 1.7, drop it manually to about 1.2V.
Edit: Just now saw the picture you updated. The max temp must have been during some more intense usage, but the idle ones look OK.
