Not sure whats going on
williamMs39426
78
Hello everyone, I an not to sure what is going on with my system. I have completely upgraded my system. the build that i currently have is, An Asrock Z97 aniversery motherboard with the latest BIOS' Intel I5-4440 3.1Ghz, APower AK series 850 Watt PSU, 250 GB SSD drive, Nvidia GeForce GTX 950 GPU, Corsiar h100 liquid cooled CPU cooler,and 24 GBs of ram, and this might be the problem but who knows it is hooked to my 52" 4k 3D TV.
Ok so now that you have an idea of what i am working with i will let you know what my issue is. It only dose it when i am playing TC's The Division. my computer will all of a sudden restart. Now my question is what is causing this to happen the GPU over heating, and if so what can i do about it, and if not what is your opinion. there is no message for not suhtting down improperaly and 1 time while i was watching netflix i got a green screen and PC froze how can i fix this problem so i can get back to playint TC's The Division, Please And thank you for your time
Respectfully
Will ( williamMs39426)
NOooooooooooooo! Apevia sells PSU-shaped objects that are unfit for purpose. Lacking protection circuits, competent technical reviews have found them not good for even half their labels, so when they blow, they may take attached components with them into the fiery abyss.
Yeah you don't want to trade one crap PSU for another. You might as well call up the train company and have them send you a shipment of 1000 units your way. All aboard!
Jokes aside, if it means not being able to use the PC until you get a new one of actual quality, then let it be so.
Oh no...not as bad as Apevia, but budget CM PSUs aren't a whole lot better. They may also be missing protection circuits (including some claimed on the box), and may also be overrated. There was at least one cheap 500W CM PSU that actually could do 500W, but was horribly inefficient. Iirc, another one could do 430W before burning. That's enough for a GTX950. At the very least, make sure you use a good surge suppressor with it, and treat it like a 430W PSU.
I am not sure of the model # but so far so good, and i understand that they aren't very much better but as of this very moment begger's cant be choosers. and you were abslutely right about it being the PSU that was giving me problems
I'm sure it's still better than what you had, so that is a step up 😉
