Hey guys, I unscrewed my cooler master seidon 120m from my gigabyte 970a-DS3P earlier to reapply some thermal compound, but when I went to screw it back in, the place to put the screws in were moved.
After trying to angle the screws for half an hour, I moved the computer and I noticed that the area to put the screws in moved, leaving just the four holes in the motherboard. Could somebody explain to me what happened, because I believe something may be loose.
Here are some pictures:
http://imgur.com/HMytM3r - Here you can see in the upper right-hand corner that there is a place for the screw to go.
http://imgur.com/WV1z0p8 - In this picture, it is not there and neither are the other four due to me moving it around. I need this computer for work and it is 100% required to be fixed within the next 24 hours. Any help is greatly appreciated!
