NT27E Neotec Monitor Woes
G
Guest
Guest
Archived from groups: rec.games.video.arcade.collecting (More info?)
Appears screen is getting dark and red is almost gone, any ideas?
Thanks
Mike
tube needs to be rejuvenated or flyback is going bad. Maybe one of the
color transistors on neck board have died. If it is a medium res monitor,
sometimes just one of the color transistors will make the monitor look real
dark. You might be able to tell which one is going bad if you have a meter
on diode test and compare all three and hopefully two will read the same,
and then you will know which one is bad.
Trin
"Mike Purcell" <MPurcell@nospamhfx.eastlink.ca> wrote in message
news:jt1Yd.12682$ZO2.10553@edtnps84...
> Thanks
> Mike
Trin;
Thanks, I'll look into that right away.
Thanks
Miek
"Trinity" <nospam@nospam.COM> wrote in message
news:WI9Yd.17$gD6.15@fe02.lga...
> real dark. You might be able to tell which one is going bad if you have a
> meter on diode test and compare all three and hopefully two will read the
> same, and then you will know which one is bad.
> Trin
>> Thanks
>> Mike
