[SOLVED] ntoskrnl.exe bsod problems
Justhea
44
Hi!
so i mostly encounter bsod in my system and when i open the blue screen viewer it tells me that it was being caused by ntoskrnl.exe and can someone help me resolving this
i would like to send the minidump files but i dont know how to upload in mediafire it says it needs permission for it to open
i haven't used media fire before, is the problem uploading or giving us a link?
You could try google drive or Onedrive
Onedrive - https://www.dummies.com/software/microsoft-office/how-to-share-files-with-others-with-onedrive/
Google drive - https://support.google.com/drive/answer/7166529?co=GENIE.Platform=Desktop&hl=en
no motherboard? :)
Dumps would show it anyway
BSV always blames ntoskrnl as it is what crashed. It doesn't tell you why though. NTOSKRNL = windows kernel. It handles all driver requests, power management, and memory management. It sits between Hardware and Applications. It got blamed but its not the cause
Hi, I ran the dump files through the debugger and got the following information: https://jingoismwheel.htmlpasta.com/
File information:060120-45656-01.dmp (Jun 1 2020 - 09:04:26)
Bugcheck:IRQL_NOT_LESS_OR_EQUAL (A)
Probably caused by:memory_corruption (Process: System)
Uptime:0 Day(s), 2 Hour(s), 23 Min(s), and 53 Sec(s)
File information:052720-60687-01.dmp (May 27 2020 - 09:24:25)
Driver warnings:*** WARNING: Unable to verify timestamp for rt640x64.sys
Uptime:0 Day(s), 0 Hour(s), 02 Min(s), and 32 Sec(s)
File information:052720-46515-01.dmp (May 27 2020 - 06:04:06)
Uptime:0 Day(s), 0 Hour(s), 04 Min(s), and 01 Sec(s)
File information:052720-46484-01.dmp (May 27 2020 - 09:01:53)
Uptime:0 Day(s), 0 Hour(s), 03 Min(s), and 20 Sec(s)
File information:052720-42359-01.dmp (May 27 2020 - 08:57:56)
Uptime:0 Day(s), 2 Hour(s), 21 Min(s), and 43 Sec(s)
Possible Motherboard page: https://www.msi.com/Motherboard/A320M-PRO-M2-V2
You have the latest BIOS already installed, version 3.4W.
This information can be used by others to help you. Someone else will post with more information. Please wait for additional answers. Good luck.
ummmm im currently repairing the said driver does it really take long?
no motherboard? :)
one caused by realtek lan drivers
https://www.realtek.com/en/componen...0-1000m-gigabit-ethernet-pci-express-software
see if that helps, the others aren't so clear.
both of what?
