Nvidia 9800GX2 Power Requirements
It doesnt NEED that tahts jstu what you are told so theres not any chanfe of their reccomendations destroying your computer. most high end but nto enthusiast computers consume like 300 - 400watts. 7900GTX needed like 100watt but GX2 needed just 130, so theres not at all much reason to assume this will need a ton of power.
Probably just over 150watt.
The comparisons with power consumption between the 7900GTX/7950GX2 and the 8800GTS/9800GX2 may not be the greatest. The 7950GX2 used mobile GPUs while the 9800GX2 is rumoured to be using the normal desktop version of the 8800GTS G92 (or perhaps 9800GTX if they are indeed identical other than clockrates) but at differing clockspeeds. The mobile GPUs required much less power compared to their desktop counterparts.
Never know, NVIDIA may pull a fast one on us and mimic the previous iteration of this product.
