Archived from groups: alt.comp.periphs.videocards.nvidia (More info?)
Hi, I hope someone out there can help me with this. I have a FX 5900
card with 256MB RAM that is connected to my TV via an S-Video cable. My
OS is Windows Media Center 2004. When I run the card under driver
version v6.14.10.4404, I have no problem displaying the desktop or
video in color. As soon as I upgrade to the latest nVidia driver
(v71.04), I get a black and white picture with black borders all around
the screen on the TV.
I searched the nVidea FAQ, and the only thing that I saw about a "black
and white" picture said to go into the advanced display properties and
make sure that the signal settings are correct. I did that, and it is
set for M/NTSC, which is correct for the U.S.. The "video output
format" is set to "Auto select". I changed the cable select
specifically to S-Video, but there was no change when I rebooted. The
only other thing the FAQ suggested was to make sure that the S-Video
cable was less than 12 feet long. Mine is only 6 feet, and besides, it
used to work fine before the update.
Does anyone have any idea what could be wrong? If you need any more
info, please ask.
Thanks!
Larry
info, please ask.
Thanks!
Larry
