Hi guys,
A little bit of background before i dive into the problem. My graphics card GTX 670 ftw used to crash the windows kernel driver every time my mouse was idle and it became a pain, therefore I RMA'd the card and got a new one. The new card did the same thing when I put it into the machine, so I was at a loss and luckily I found a thread that mentioned the same problem and it was in fact a process called ieghutil.exe or something along those lines stored in C://Temporary which is a form of malware that mines bitcoins and therefore maxes your grpahics card usage and crashes it. Once i got rid of that, everything was good! Which made me think I did not need to RMA my previous card in the first place!
Well onto the problem at hand, I had the new card going just fine on dual displays HDMI and DVI-D slots for about two days and then suddenly last night. I come to the computer and my HDMI screen was in sleep mode and when I went into the NV control panel app, it still showed my BENQ HDMI monitor but it could not be enabled. After a restart, things went downhill as my computer would not really boot into windows, no boot pictures would show up and It would just turn off after a minute. I tried reseating the card into the slot and clean some dust off the case fans etc but no avail.
What did work was using the DVI-I slot with my other DVI monitor (LG Flatron 2232TQ) and it worked and booted up fine but it will not detect HDMI any more whatsoever. Once i boot into windows using DVI-I, I can disconnect and put it into the DVI-D slot and it works the same BUT it will not boot when the cable is in the DVI-D slot.
I am sorry this post is rather long but I wanted to be precise and detailed so I can make it easier on you guys.
My build:
i5-3570K
GA-Z77-DS3H rev. 1.1
OCZ Vertex-3 SSD
Seagate Barracuda 2TB HDD
BenQ 2220HD 1080p
LG Flatron 2232 TQ 1050P
EVGA GTX 670 FTW
Please let me know what to do and what you guys think!
Thanks heaps for your help!
EDIT:
I bought another DVI-D cable and hooked it up to the gtx 670 and everything was going fine for a while and I was playing Bioshock Infinite etc and suddenly the monitor with the new cable in the DVI-D slot starts flickering etc. and then it dies like the HDMI too 🙁
Now I am stuck with one screen and every 15 minutes, the screen with DVI-D port will come on for maybe a minute before turning off saying there is no signal.
Since i cross-shipped RMA, my old card is still in the US about to be shipped to EVGA, should i stop that and get it sent here and maybe send this one back?
My build:
i5-3570K
OCZ Vertex-3 SSD
BenQ 2220HD 1080p
EVGA GTX 670 FTW
EDIT:
