i assume this is a p4 system? if its one of those ones that is black, and has a dark grey front, like my dimension 4600, then it comes with a 200 watt power supply...
Also, I tried a nvidia 7600 but it wouldnt work either. I found that it was a 8X card and it had molex power adapter. The monitor wouldnt even try tp power up (light stayed orange) with this card the light turns green but doesnt display anything.
Uhm, no response from monitor, could be lots of things...
Dodgy card may not be working, try testing it in another PC if you can.
Need new drivers, pretty simple one to update....
my system has diagnostic lights, the bad card I am replacing the lights show a code for "video controller failure" the new card I installed does not show and diagnostic codes. What do you think?
My system has the diagnostic lights, the bad card I replaced showed a code for "video controller failure" the new one did not show any codes. what do you think?
