Question NX800 front panel
Samsonob12
20
On my pc case packaging/instructions it says front panel is removable but can't find anything that actually shows how to remove it, searched the internet and no one seems to know the answer.
You should be able to slide your fingers under the chassis' front panel and you should feel a notch cut out into the bottom of the front fascia. This notch is to insert fingers and tug at the front panel. I'd ask you to do some scouting, take off the side panels of the case and see if the front panel is held to the chassis with screws or plastic pegs(...?).
