NZXT 530 Phantom, Fan Hub not working
Calotron
19
Recently bought the NZXT Phantom 530 and it has a fan hub on the back. None of my fans are getting any power from this hub. I've looked already trying to find someone who had a similar problem but cant seem to find anything.
I know the 3 pin port at the tob of the hub is for power. I trace that line back and it leads to the fan controller on the top of the case. The rest of the 3 pin conncetors are all labeled fan 1 - 8 so I know those cant be power. I read somewhere about a molex power source? I have no clue where that would go on the hub. My MOBO (ASUS Sabertooth m2 z97) came with a 4pin to molex connector, but again they are only 3 pin on the hub.
Am I missing something stupid? I hope so because this is pretty frustrating, any and all help is greatyl appreciated guys!
Would this connector already be attached to the fan hub? As I said, I traced all wires coming from the hub and they all just lead to a fan, or the fan controller on the top of the case. I will triple check when I get home, but I'm almost 100% possitive I didnt see anything. All the connectors on the fan hub are 3pins also, and I know I didnt see a 3 pin to molex.
Thanks for the tip though, I'll give it another shot! :)
This is a great find and a good sign that I'm just blind as a bat! This is the first video where I've seen that cabel. Glad you found it. I watched a few and they only mentioned the hub, barely showed it off. Cant wait to get home and check it out. Really appreciate it Alexoiu. I'll keep you updated.
