Hi, I have the fan control hub that comes with the nzxt h500i and I was wondering if the hub will work with a fan splitter. It only has three ports that I can see and I need 5.
Located under the Smart Device's section in the manual for the case, you can have three fans off one header on that hub. That means you can have a total of 9 fans if you use a 3 fan splitter on each of those channels.
