nzxt h440 front ios installation
Snodfather
89
im having a little trouble, my leds aint working on the case with the psu installed and i dont get why, can someone help me with a picture or something the exact way the PLED + and - sw pwr cables go exactly, doesnt matter about the usb and audio i got that, but them little ones please help ?
i have a perif wire from the psu with female molex on them and connected it to that exact wire, and no the fans are not running, bare in mind i do not have the cpu yet but still, im getting power
yeah thats what i have done but, nothing.
well i just want the logo leds to work and i want to know/see the correct way to put in all the wires for PLED+/- SW pwr into the motherboard
yeah give me one second, ill post it to you in a sec and i dont see why id need the cpu n though, especially when other people dont need it in to work them
no the wires to plug into the motherboard is for my front panel ios, i wanna know if they are in right
Oh, I know what you're talking about, silly me. The front panel LEDs and all those things plug in as so:
i never had a speaker wire though ?? ill show you with pictures
is that all plugged in correctly and yeah i can also just plug them straigh into the mobo but this came with the mobo so, have i got the +/- the right way round ?
ok so, ive just used my 24 pin tester tool than came with the psu and all the fans, leds all shot straight on when i put the power on, but how come they are not working when the 24 pin in plugged to the motherboard ? even though the lights on the motherboard show that im getting power to it ?
http://i.imgur.com/D6kPWWy.jpg
no, it can only go in one way ? and no im not ? should i be ?
Hmm are you wearing socks?
You should be grounding yourself, especially when on carpet. Otherwise, you risk the chance of zapping your motherboard without realising it and, well, frying it. It is a very rare thing, but I noticed you are on carpet. I stand on carpet, but I go barefoot with flip flops when I work on my PC, and I use an antistatic wrist band connected to my other PC's steel to ground myself and prevent this from happening.
A wrist band is not necessary, touching a grounded piece of metal every so often works too. Read this http://www.tomshardware.com/forum/322660-30-ground-yourself
so do you think ive damaged my motherboard ? :/
