NZXT H440 - Window replacement
tazzrats
97
So, I tried to clean the window for my H440 and this cleaner has something in it that melted the acrylic of the original window -_-
I have a local glass merchants that can make a glass window for the case; question is do glass windows work / look okay in cases? I would love it if anyone with any experience or more know how than me could let me know 😀 Thanks in advance!
yeah if its plastic soft cloth soapy water and elbow grease--but guess the op knows that now
hardly any cases ship with glass windows so that should give a clue that there are reasons why they use perspex
its lighter-cheaper-easier to cut and drill holes in doesnt shatter with temperature changes are a few reasons i
can think of
Yep I have definitely learned my lesson the hard way :') BUT I don't have any of the tools required to cut a new piece of perspex; guess I'll have to get all of that too; thanks!
It would make a great fish tank after using it as a PC if glass were installed. 😉
not saying you cant use glass--in my opinion yes it would look better than perspex/acrylic but you would have to see how much it would cost and ask the glass merchant about any potential issues using it on a pc case such as temperature changes and vibration and would have to be more careful if transporting it somewhere
lol--reminds me of those fish tanks where they submerge the pc in mineral oil--though they didnt put fish in as well obviously
haha; I feel i deserve to turn it into a fish tank -_- I didn't think this cleaner had any acrylic killing chemicals in it, i think it must have alcohol in it -_- thanks for all the help though, going to pop and get some perspex then; last thing i want is to put glass in that causes more issues :')
And you'll learn some new skills along the way, it all helps. 😉
