[SOLVED] Nzxt h500 case esd
Jun 3, 2020
Hi I just bought this case and built my computer should I have to worry if I have static with the case the case is on my desk so should I have to worry if I have static with the case will it damage the parts inside? Please help I’m freaking out
You should be fine working on your PC on your desk just stay away from working on your PC on rugs or carpet. It is always a safe measure to ground yourself to the case while working with the components inside. You're fine there is nothing to be freaking out about.
