Hi,
I bought the NZXT Phantom 410 awhile back and fitted it with several fans. It comes shipped with an NZXT Branded 140mm white LED fan at the top and I wanted to purchase a second identical one in the second slot. The problem is, I cannot for the life of me find out what it is! Can anyone help please?
The only LED fan I found on NZXT's website is the FZ 140mm LED fan, which I purchased as a substitute but I'm tired of it looking uneven (one fan is solid white, the other has clear see-through fan blades).
So, determined to find the exact model I looked at the rear of the installed fan and this is what I found: http://s29.postimg.org/n4zh0hp3b/DSC_0305_1.jpg
As you can see, it doesn't specify a model number but it does have other useful information. The first, the white ring around the outside. I'm guessing this is used for either the family of fans or the LED colour of the fan. You also have the ampage and wattage values too.
I then matched those values and characteristics up with the fans on NZXT's website and found the FN 140mm RB to match both aesthetically and the values given (0.24A, 2.88W) http://www.nzxt.com/product/detail/87-fn-140rb-case-fan.html
I went ahead and purchased it on Amazon making sure it had the same values: http://www.amazon.co.uk/gp/product/B0039825LW/ref=oh_details_o01_s00_i00?ie=UTF8&psc=1
But when I finally got it, I noticed it ISN'T LED and the values on the box are different to those found on the original fan:
http://s15.postimg.org/trje3asm3/DSC_0300_1.jpg
http://s27.postimg.org/lv761xik3/DSC_0301_1.jpg
I'm now quite puzzled as it's still the same fan FN 140 RB but with a lower wattage (2.16W, 0.18A) to accommodate for the lack of LED's AND it has a blue ring too, rather than a white one which is infact pictured on Amazon and NZXT's site too.
Has anyone found any luck with this? Any help would be appreciated.
