NZXT Phantom case fans
mikeJT
Using this case
http://www.nzxt.com/product/detail/34-phantom.html
Looking to replace the top wonky sounding 200mm(possibly install the second top as well as the side). Any recommendations? Noise is a concern, leds not a concern, price a concern. Looking to get a R9 280x upgrade (not sure if Sapphire or ASUS yet, any suggestions?) as well as HDD upgrade and wanna keep my CPU and GPU cool.
I have the original phantom as well and I was after 200 mm cases a while ago , took me some time to find them where I live.
I would recommend going with the NZXT case fans (200 mm ones).
I would say their updated version for the 200 mm fans is good , link to the fans on their site : https://www.nzxt.com/support/index.php?/Knowledgebase/Article/View/33/30/fs-fan-specs sadly look like they are discontinued .
Found some on Amazon : http://www.amazon.com/NZXT-200mm-Silent-200RB-Black/dp/B0046W7Y84
They are ~20 db. only and honestly the mound on the phantom is bit unique I'd say.
I tried to mount a Thermaltake 200 mm fan and it did not fit.
Happy hunting .
check out a Bitfenix spectre.
http://www.newegg.ca/Product/Product.aspx?Item=N82E1683...
it's the quietest fan in my system.
(ASUS is the better of the two for your card.)
Are you currently running these? I was reading the reviews and several were saying they didn't pull enough air.
I would say their updated version for the 200 mm fans is good , link to the fans on their site : https://www.nzxt.com/support/index.php?/Knowledgebase/A... sadly look like they are discontinued .
Found some on Amazon : http://www.amazon.com/NZXT-200mm-Silent-200RB-Black/dp/...
Happy hunting .
Were you using these fans as well? Did they pull enough air for you? The RPMs and CFM's look a lot lower than the standard FN models.
yes infact i'm using a 120mm spectre on my cpu no problem which should be enough proof for airflow
