So quick question...I just now learned that corsairs QL120mm fans aren't good for radiators (not static pressure fans from what I understand).
I ordered 9x QL120mm fans for my build, (case is Lian Li-PC011 Dynamic). Well, now knowing the QLs shouldn't be put onto the NZXT Z73, i'm unsure what to use. I wanted to stick with rgb fans for the overall theme, and this is the first PC i'm building myself so I don't know very much.
Would I be good using the ML120mm fans by Corsair for the Z73 aio, or should I use NZXT AER RGBs? Any help would be appreicated! (Also, my mobo is a Asus ROG Maximus XII Hero)
Full specs in case you need the info;
i9-10850k
Kraken NZXT Z73 AiO
64gb Trident Z Royal
EVGA Supernova 1000w platinum
PNY RTX 3080 XLR8
1tb nvme ssd
1tb nvme ssd
2tb ssd sata
Case; Lian Li PC-011 Dynamic
Fans; (3x) intake bottom - QL120mm corsair fans; (3x) intake side - QL120mm fans, (3x) exhaust on the radiator (brand??)
Thanks again!
i9-10850k
Kraken NZXT Z73 AiO
PNY RTX 3080 XLR8
1tb nvme ssd
1tb nvme ssd
2tb ssd sata
Thanks again!
