I'm about to build a gaming machine built around an i7 2700k, ASUS P8Z77-V Deluxe, cooled by an h100i. The rig will be used for flight simulation and gaming.
I'm confused about how overclocking works with Hyperthreading, Speed Step and the turbo boost.
What I want is a system that runs at 4.5ghz all the time. I'm hoping with the h100i that will be possible.
Should I disable all of these options?
As I understand it from reading the mobo manual, I can oc the turbo boost using Asus's software. But I have read mixed reviews of this approach - esp. sluggish performance with undemanding programs.
What about Speed Stepping. Will this function work with a manual OC and if it will, is it even desireable?
And finally HT. On or off given what I want to do with the box.
Thanks all for your patience. There is an awful lot of info out there, with a lot that is contradictory. I'm not a complete novice - this is my third build - but please try to explain in plain english. History major building a computer, not a double E.
Thanks!
Colin
Thanks!
Colin
