Octigen M170E5 Monitor picture blinks, LED ON, hissing sound - HELP!
CtrlAlterDead
40
Hello to All,
Its about monitor Octigen M170E5 failling to display picture repeatedly.
Very loud hissing sound heard from the back, continuous.
Took it apart and make some inside photos.
On the back of the Mboard that provides power is extra element, solderd by hands as seen on photos. Residues of solder also very near to this element.
Pic1: https://drive.google.com/open?id=0B6dT-dSe7oVOMjBBRUlVZUZWN2M
Pic2: https://drive.google.com/open?id=0B6dT-dSe7oVOeTBWM0RpaWoyN0U
Pic3: https://drive.google.com/open?id=0B6dT-dSe7oVOOWpGRFF4aFUyUzg
Any thought on this problem.
Thank you All in andvance
CtrlAlterDead
40
Ok. Next thing is to look for domed caps on both boards.
I have a multimeter and its digital one.
Am I doing circuit inspection for
voltage drop on menu board while power ON, or OFF?
CtrlAlterDead
40
Ok. It will take same time do it properly.
Power button ends on video ctrl, and then through 12 pin connector video ctrl is connected to power board just to make sure what I looking for?
Will proceed with caps check.
CtrlAlterDead
40
Hi there,
Is this post considered SOLVED? Don't think so? What is exactly that I have to do to make it like that.
Just so you know, I m using this monitor all the time and didn't do anything else with power board, except checking for bad caps. I m okay with state of it, it's doing the job, listing all products and services on a front door of my Co.
Thank you once again ffg7
You started this thread as a discussion thread not a question thread, I have just changed it for you so now you can pick a solution and mark it as solved if you wish.
