Odd behavior between boulder and dismounting
G
Guest
Guest
Archived from groups: rec.games.roguelike.nethack (More info?)
So, I've noticed a bit of odd behavior when my knight dismounts from my
mount next to a boulder in narrow corridor.
When she dismounts, she often end up being in the same square as the
boulder square, with all of her equipment and inventory in tact, and no
'squeezing in' message. This happens even if there's a space in the
other side of the mount she can dismount to.
I also can't tell if this behavior incurrs any Sokoban penalty.
Is this intended or a bug?
-K
Nevermind...I found this on the bug search. I have to check NH
version. It should be fixed in 3.4.3 😛
-K
> You really should be playing 3.4.3. Lots of bugs fixed.
I thought I was. Which is why I should check it.
-K
Kevin Wayne
"I came to Casablanca for the waters."
"Waters? What waters? We're in the desert?"
"I was misinformed."
