Ok eddited builf and final build what u think?
shawnlove
157
SAMSUNG 24x DVD Burner - Bulk SATA Model SH-S243N/BEBS - OEM $24.99
Antec Twelve Hundred Black Steel ATX Full Tower Computer Case $169.99
Corsair P256 CMFSSD-256GBG2D 2.5" 256GB SATA II MLC Internal Solid State Drive (SSD) $689.00
XFX HD-597A-CNB9 Radeon HD 5970 Black Edition 2GB 512 (256 x 2)-bit GDDR5 PCI Express 2.1 x16 HDCP Ready CrossFireX Support (2 @ $1,439.98) $719.99 each
Antec TPQ-850 850W Continuous Power ATX12V / EPS12V SLI Certified CrossFire Ready 80 PLUS BRONZE Certified Modular Active $144.99
G.SKILL Ripjaws Series 12GB (3 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-12800CL9T-12GBRL $644.99
SAMSUNG Spinpoint F3 HD103SJ 1TB 7200 RPM SATA 3.0Gb/s 3.5" Internal Hard Drive -Bare Drive (free with the ram) $0.00
DFI LP UT X58-T3eH8 LGA 1366 Intel X58 ATX Intel Motherboard $279.99
Intel Core i7-930 Bloomfield 2.8GHz LGA 1366 130W Quad-Core Desktop Processor Model BX80601930 $288.99
Microsoft Windows 7 Ultimate 64-bit 1-Pack for System Builders - OEM $174.99
grand total of $3,881.34 after shipping and tax
so am i missing anything or could i get something better for a cheeper price or not much more or great as is?
those 5870's are OCd much higher. Just accept the fact that four way 480's is insanely better in terms of performance(10percent orso with premature drivers). It may heat you room and turn off the lights but it performs far better.
because if the 5870 was as hot and as power hungry it would run circles around a gtx 480 backwards the 5870 is just a better gaming card then a gtx 480 its like a choice between a ferrari and a tank yeah the tank has its uses but it could never do what a ferrari does but at the same time a farrari cant do what a tank does i respect both companies on their own terms but nvidia seriously dropped the ball on the gtx480 series
thoes are dual channel kits i want triple channel
it doesn't really matter if its tripple channel or dual channel. Its the same ram just in different sets, but if you take 3 sets then you have tripple channel.
Tripple channel just means that the modules fill up 3 channels. Which the case with 3 of those sets.
And boy that is fast ram I didn't know 2000 cl6 even existed.
