im going to be building a gaming rig with a cm elite 130, im going to be placing it in a open air rack under a desk, it will have open air on five sides, top right front, back and bottom, but the left side is less than half a inch away from a wall.
I noticed the left side of the elite 130 has the vent holes for the graphics card, and since im going to be getting a 290 or 700 series im thinking about rotating the case in the rack so the bottom is against the wall, and all other sides have open air.
my question is is this ok, will this cause any damage or durability issues.
I do notice the elite 130 has a alternate spot for a hard drive so I can put it on that which makes it vertical, until rotated, which will put it horizontal, but the dvd is stuck at horizontal so if rotated will be vertical.
thanks in advance for all you experts, I would be screwed without you.
